flighttime1
Flight distance : 906352 ft
Autopilot is built with the DJI API which means it's tied to the the Go app in many ways. Autopilot is meant to fly missions, it will not help you select the best channel or a ton of other necessary settings. When you change a setting in the Go app, it's stored in your craft and Autopilot uses those settings. I typically start up with the Go app and then switch over to Autopilot after getting the bird up and changing all of my camera settings in Go. You really don't want to ever consider it as a replacement app. That is not what it was created to do. That said, if you want to extend the capabilities of your bird, it's the number one app to use.
One item that is missing from Autopilot, or that I've never seen, is the ability to review the video on your SD card. I always switch back to the Go app after a mission to check for any changes that need to be made. If that's something I've missed, please correct me on this. |
