greyphantom2
Flight distance : 787474 ft
New Zealand
I see the specs for the Osmo and Osmo+ and the controllable range is -35° to +135°. Does that mean that from a forward pointing flashlight position you can tilt it up past vertical (looking straight up)?
I would like an Osmo that can look from horizontal to straight up.
I also see the Osmo Pro tilt range is quite different -90° to +30°. Does that mean it can only look above horizontal by 30°.
Where is the tilt range measured from anyway? Is it horizontal or is it from the main axis of the handle?
Cheers
Caleb |
