H3 3D gimbal dead
1050 2 2015-2-4
michaelgulley.e
Hi
I got a second hand H3 3D which I got cheap because it was faulty.
I installed it on my Phantom 2 and it would point to the right. otherwise it would work ok. I connected the assisiant software and the gimbal was recognised then I upgrade the gimbal but that did not fix it. I tried the reset with tweezers a few times now there is no light and the gimbal motors don't move. I plug in the assistant software and the gimbal is recognised but still a dead gimbal. Assistant software says gimbal driver is up to date.
Can anyone please help me.
Thank You
Michael
2015-2-4
michaelgulley.e
Fantastic I got it working and its all due to you all out there with your posts. I went through the reset routine about 4 times and magic it now works. The yaw motor also had a little grub screw which was loose which I tightened and the yaw works now. I must say you are all STARS out there thank you for the valuable posts
Regards
Michael
2015-2-4
DJI-Autumn
Glad those posts could help you out with your prob.
2015-2-4
