pimezon1.email
Thanks For your answer
Taheo_Ed ! Are you sure fast multi?
Did I understand true?
Before I will calibrate in LB assistant. ( futaba connected ground LB) ( System (a2,lb,gs900) works)
After I will calibrate in the A2 assistant. ( still futaba connected ground LB ) ( System (a2,lb,gs900) works)
I calibrated futaba. Elevator and throotle reverse is wrong in LB. Elevator and throotle is true in A2.
ALso signal of futaba is zero on the dislay o LB.
But A2 knows futaba.
What should I do?
