Charging Battery
418 4 2016-10-29
Jake Phantom 3
Flight distance : 2639747 ft
Question about charging battery. Going out to fly, battery is at 83%. Is it ok to charge it full to 100% so I'll be starting with a full charge. Or will topping off hurt the battery. I know on the toy version drones you were supposed to drain the battery before charging. What's the case with these bigger batteries?
2016-10-29
afiend69
Flight distance : 529518 ft
http://forum.dji.com/thread-36544-1-1.html
2016-10-29
Jake Phantom 3
afiend69 Posted at 2016-10-29 09:12
Old post I have never seen. Thanks, it answered more questions than I knew I had. Good learning tool and should be available for battery care where everyone can see it.
2016-10-29
wmcvey
Flight distance : 904364 ft
Nothing wrong with topping off your battery, really it's the right thing to do. Going with a fully charged battery is ALWAYS better. You don't have to drain the battery on every charge.
2016-10-29
Aardvark
Flight distance : 384432 ft
Jake Phantom 3  Posted at 2016-10-29 14:17
Old post I have never seen. Thanks, it answered more questions than I knew I had. Good learning to ...
One caveat to that post, it says if left more than 24 hours to discharge to 90% and then top up. The battery can be triggered to do a top up charge by switching it on while connected to charger. So for example if battery was showing 97%, then no need to take it down to the 90% threshold; just switch it on when connected to charger and it will top up from 97-100%.
2016-10-29
