jpaydirt
Flight distance : 2969 ft
Same thing here, sat for a month then out of the blue quit, I bought a new module and nothing, put the old one back in and boom it worked, for a while, now its not, does your controler say update required? do you leave your phone/device hooked up, have you blocked the apps ability to update, do you have your device's wireless on when flying, I'm asking because I am running 2.4 app and 1.4.1 copter 1.3.20 RC and have not updated because it worked for a year, why update if it works, who wants all the bugs So my question is if the GO APP can't update why does mine say update required and now won't fly, dji says theres no way for it to update, but I say if they can make the controller show a warning then what stops them from disabling the RC if you don't update, because if I update then I have all the flight restrictions NFZ's hmmm? Try removing the ribbon cables from the usb module then turning on the remote and then turn it off, re attach the cables and see if that works, this will reset the module, if you were running old firmware, and old ios your issue is not phone or tablet related, just my opinion after reading everything I could find for the last two weeks, you are the first I have come across with the same problem as mine, go to facebook and find Lyhn phan he is a drone guru, It could be something else, but why would it go from working fine to not working after sitting? |
