Stable at 2-3m above ground, wobbly at 30m+... is it wind?
478 7 2016-10-29
VoxUltrasonic
Flight distance : 328602 ft
Hi guys, I just need some confirmation that I'm not going crazy here.
I've had my Phantom 4 for a couple months now, and all has been GREAT. However, my last two flights have been a bit shaky...
When I launch the drone and hover 2-3m above the ground, all is stable and solid... but when I take it up to about 20-50m+, I notice the Phantom is doing "donuts" and generally drifting. Is this squirrely behaviour due to wind, or something related to GPS? Having only a little bit of seasonal experience (majority of my flights have been in sunny weather until now).At one point I was noticing the LED's coming in and out of the shot as I was trying to return home. First time I've experienced the drone to "feel" pretty unstable.. I didn't notice much wind on the ground aside from the odd light breeze, but was also in an area with trees... Might have been more wind higher up?
Anyone have a similar experience?
For context, I'm located near Vancouver, Canada.
2016-10-29
davemajchrzak
Flight distance : 3372566 ft
I flew mine in about 15-20mph wind the other day at about 200 feet and it hovered perfectly. However today I had my Phantom about 5 feet in the air and it kept starting to sink and move left and right a little bit, I restarted RC and quad and it seemed to have fixed it. Sounds like you have either a GPS or satellite issue but I could be wrong.
2016-10-29
Bond
Flight distance : 1364534 ft
Have you calibrated your IMU?
2016-10-29
nigelbrinkmann
Flight distance : 577484 ft
Is it the same area were you normally fly?, normally wind doesn't affect the drone like you have explained, if it did you would defiantly feel the wind while you are flying!
2016-10-29
VoxUltrasonic
It occurred where i usually fly. I will try calibrating the IMU!
2016-10-29
DJI Natalia
Super Moderator
Flight distance : 318 ft
How about the GPS signal? please try to calibrate IMU firstly then compass in a location without interference.
And you could change another location to test whether it's the same case.
2016-10-29
Aardvark
Flight distance : 384432 ft
Remember that VPS is operational for the first 10m above ground, I would expect the P4 to be near rock solid up to that height. Above that there will likely be some movement, depending on the accuracy of the GPS/GLONASS in 'P mode'.
Edit:- A full good calibration as previously suggested may help fix things. With all connected and powered up you could get some idea of the state of the IMU by looking at the readings 'Main Controller Settings'/'Advanced Settings'/'Sensors'.
2016-10-30
VoxUltrasonic
Calibration worked! Thanks everyone.
Also that totally makes sense about the VPS.
2016-10-30
