Tripper Dog
As ladroides said, you can "override" the RTH speed, which doesn't affect the RTH functionality or mode. 26% is low, but unless it's an old battery with a "memory", you had plenty left. I normally fly my drone till it won't fly anymore, which is around 8%....I do this to drain it all the way down. I also do this about 2 feet off the ground and in a field behind my house, or just let it hover a foot off the ground until it lands itself. Then, it won't fly anymore. I've had plenty of flights where I've come home with low battery...The drone will calculate what it needs (with a safe margin) to get back. But, you can of course, speed it up if you are concerned. I certainly wouldn't fly any distance away with less than about 18%, and that is cutting it close. Also, depends where you are flying, height, objects around and etc. I use mine to exercise my dog and he chases it while 5-6 feet off the ground and it's not unusual for me to fly around 10-15%, but I keep a very close eye on it. It will automatically land when the batter is about done.
I cannot answer your voltage question. Sorry. |
