Prop Balancing
2240 13 2016-10-30
Peel
Flight distance : 10876 ft
Has anyone come up with a method for balancing the props on a Mavic? All the videos I've seen on this topic use spin on props that are hub-centric. With the Mavic having the bayonet mount it doesn't seem this would be compatible without creating a special rig. Thoughts?
2016-10-30
skyrider420
Banned
2016-10-30
hallmark007
Flight distance : 12400594 ft
Probably 99% won't bother I don't have Mavic yet so don't know can vibration be improved, but I'm not likely, I know there are some guys over on P4 forum who have dappled with balancing props, so my advice would be pop over there an post a thread you should get some good advice, I don't think you will get a response like . No need.
Good luck and enjoy your Mavic..
2016-10-30
sploodge
Flight distance : 809350 ft
Like said, no need.
2016-10-30
StianGel
Flight distance : 686654 ft
Norway
Looks like there are two commonly used method's.
One is too lock each blade in it's extended position, but i don't think that is possible on the Mavic propellers. They use pins instead of screws. (As far as i know.)
The other way is to disassemble the propeller and weigh each blade on a precision scale.
I always balanced my propellers on my current quadcopter. It really helps to cut down on vibrations.
2016-10-30
Tahoe Ed
Flight distance : 41668330 ft
Don't bother to try to balance them.  It is a waste of time.
2016-10-30
AusAir
Flight distance : 425049 ft
Never found balancing a waste of time even with top of the line props. Sure they're flyable but they're far from perfect.
2016-10-30
Daveman
Tahoe Ed Posted at 2016-10-30 18:50
I agree Ed, although I cannot speak to the Mavic props until I get them.  Historically, any original DJI branded (non-fake) props have always been well within tolerance and rock solid.
2016-10-30
AusAir
Stick them on a balancer then see how perfect they are.
2016-10-30
Peel
AusAir Posted at 2016-10-31 10:53
But that's my question: how do you mount a bi-pin, bayonet type mount on a balancer?
2016-10-30
erneststrauss3
Flight distance : 29406 ft
Peel Posted at 2016-10-31 11:10
I'd go with the DJI rep and not waste time While you think you are balancing them, its only statically balanced. Who knows how you are changing the aerodyamics.
2016-10-30
DJI-Ken
DJI Team
Flight distance : 1515312 ft
Personally, since the P3 I've had no reason to balance props.
I'm sure soon someone will come up with a balancer but I really don't think it's necessary.
2016-10-30
Gray Volk
DJI-Ken Posted at 2016-10-31 00:25
I'm sure soon someone will come up w ...
another question: how to measure the vibration? to check if it's ok or something is wrong. one way is to look at the video if there is any wobbling. any other ways, sort of cheap sensor or somehow get out off flight controller?
2016-10-30
justin
Flight distance : 683885 ft
South Africa
Gray Volk Posted at 2016-10-31 08:49
another question: how to measure the vibration? to check if it's ok or something is wrong. one way ...
Many app available for mobile phones.
2016-10-31
