Ronin M with s900
1414 9 2016-10-31
e.gargiulo
Flight distance : 5000 ft
Ronin M with s900
I would like to connect my Ronin M to s 900. How can I do this? Thank you
2016-10-31
e.gargiulo
nobody?  thanks
2016-11-1
valealvarez.s96
Argentina
Using a special adapter, look at "cinemilled" then some sort of dampening system to isolate the vibrations from the aircraft to the ronin
2016-11-1
DJI-Jamie
Flight distance : 112405 ft
Keep in mind, however, that the Ronin M is made for ground use and is not made to deal with air resistance. A Ronin MX is better suited for both aerial and ground use and has a mounting plate to use with aerial units.
2016-11-1
e.gargiulo
Hi, Jamie. Thanks. I would use this combination Ronin M with S900 for low altitude archaeological survey (3 meters) and at low speed. So it should be no problem. By the way ... could also be mounted i the mounting plate of the Ronin MX  on Ronin M? how can I buy it?. Thanks
2016-11-4
e.gargiulo
Hi. Nobody? .......
2016-11-4
DJI-Jamie
e.gargiulo@soge Posted at 2016-11-4 16:36
Hi, Jamie. Thanks. I would use this combination Ronin M with S900 for low altitude archaeological su ...
Do you mean the Universal Mounting plate or the MX's vibration absorption mounting plate for the M600? For the universal mount, that can be found below:
http://store.dji.com/product/ronin-universal-mount?from=search
The mount for the MX to the M600 is included with the MX itself. A dealer may have this part separate for purchase, but that would require some shopping around. Since this was made for the Ronin MX, I can't say for sure that it will work for the Ronin M, but you can try it out at your discretion.
In the future it would be best if you hit "reply" to the post you want to respond to, so it will notify them.
2016-11-4
e.gargiulo
thanks .....
2016-11-4
DJI-Jamie
You're welcome. Best of luck to you.
2016-11-4
FloStone
Switzerland
Is it better to use the Ronin-MX together with the S900, or does the Ronin-M work fine with mounting plate? I have a cheap offer for the M, thats why I'm asking.
- What are your recommendations on those two gimbals? Or is there another better product to consider?
- How can the camera (A7II) be controlled and triggered in the air?
- Can the Ronin be controlled directly over the remote of the S900 / Lightbridge 2
Thanks for your answers!
2018-2-16
