spencer_hamons
Flight distance : 292208 ft
I currently use my Samsung Galaxy Tab 4 10.1" with the Phantom 3 Professional with Lightbridge and it works wonderfully. Mine is the 16gb version with a 64gb microSD for additional storage. I use my tablet for general use, in addition to flying with it.
To make it work right, you do need to use a Dremel or something similar on the bottom of the mount to allow the USB cable to connect to the bottom mount port on the Galaxy Tablet. If you don't want to do that, you can mount the tablet off-center and connect that way. I did this at first to be sure the device would work correctly before taking the Dremel to the mount. If you do want to try it, don't make the same mistake I did though. When I first tried it mounted off-center, the top of the holder was pressing down on one of the volume keys. When I tried to boot up the device, it would always try to boot into safe mode. Once I realized what was happening and remounted the tablet where the volume button wasn't being pressed, that resolved the "safe boot" problem.
Pictures below of what the setup looks like. Please - no hard time about the pre-flight notes - using that to get my wife comfortable with flying.
Spencer Hamons
Angel Fire, NM
