GMG
Flight distance : 3632605 ft
I received my Polar Pro cinema series 3 pack and finally had a chance to try them out.
Here's what I like:
- They make a big difference in sunlight, versus no filter (although I didn't do a with/without comparison...for reasons that I'll explain in a bit). Much better saturation.
- Clearly very high quality
- No issues with the cinema series when the Mavic initialises the gimbal. It pivots and swivel around without any issue.
- Customer service was excellent. I'd bought the standard 6 pack of filters and had issues with them being very hard to remove, which was a concern as they required being taken off/on before every startup and battery swap (due to the gimbal). The newer cinema series can stay on when the gimbal initialises. Jeff immediately offered to figure out a way to swap for the new 3 pack cinema series as that's clearly better. He was also optimistic that the machining on the cinema series could make it easier to remove them, as I'd expressed concern about how difficult it was to remove them from a sensitive giimbal.
But here's what I've not liked...
- While there's the benefit that I don't have to pull off the filter each time I swap the battery, the cinema series haven't been any easier to remove vs. the standard filters. Even in a warm house, its not easy to get these suckers off...and it's worse outside in the cold weather.
- A small thing, but it'd be great to ship these in a smaller case. The 3 filter case is nearly the same size as the 6 filter case and I'm trying to pack lots of stuff into a very small case. It could be about half as small and that'd make it fit into my very tightly packed hardshell case.
Design always comes up against the limitations of what you're working with and I appreciate that the design of the lens and gimbal assembly for the Mavic created substantial issues for Polar Pro. The technological achievement of the Mavic is considerable. That said, I'm surprised that DJI would've released a product that's intended to create high quality images, with a lens that doesn't offer something as simple as a thread, or some other means to secure a filter. I hope the Mavic 2 will address that. |
