Problem with Assistant2 on Mac?
1099 8 2016-11-2
fai58
Flight distance : 104439 ft
I am curious if any have any problem trying to retrieve the flight logs from Assistant2 on Mac, mine just keep loading and loading on the flight log section.
2016-11-2
SmokNyrEyz
I tried on two different Macs and couldn't get it to work. Tried on a pc, and they popped up in about 10 seconds. Definitely buggy software for Apple
2016-11-2
N3VO
Did not work for me either on apple.
2016-11-2
fans29865fd0
I was not able to update firmware on two different macs but over the air was OK.
2016-11-2
Have you tried to change another computer to load the flight logs?Also, did you install the latest version of the DJI Assistant?
2016-11-2
djoole
Yes he said he tried on 2 different macs.
This issue has been reported several days ago.
2016-11-2
fai58
DJI Mindy Posted at 2016-11-3 14:56
Have you tried to change another computer to load the flight logs?Also, did you install the latest v ...
I just tried it on windows and it is working perfectly, the Mac version just doesn't seems to work.  It might just be not compatible with the MacOS 10.11.6
2016-11-4
fai58 Posted at 2016-11-4 21:57
I just tried it on windows and it is working perfectly, the Mac version just doesn't seems to work ...
Thanks for your update.
It's probably the compatiblity issue.
2016-11-5
1efishinsea
Flight distance : 1386637 ft
I was not able to get assistant 2 to even work at all on my macbook pro !  tried for several days now
2016-11-5
