Firmware update without using assistant 2?
898 2 2016-11-3
fans826e3836
Hi there!
I updated my firmware on the matcie 600 and now all I am seeing is lightbridge 2 in the assistant app and also the light on the matrice where you plug in the USB cable is staying white? Any ideas if i can get the firmware to load through a camera like the zenmuse x3?
thanks
Keith
2016-11-3
DJI-Jamie
Flight distance : 112405 ft
The X3 firmware package for the M600 would only update the camera. Have you already power cycled everything? What version of the Assistant 2 do you have?
2016-11-3
fans826e3836
DJI-Jamie Posted at 2016-11-3 16:03
The X3 firmware package for the M600 would only update the camera. Have you already power cycled eve ...
Yes I have power cycled everything and I am running 1.0.5 on a windows 10 PC. I have also tried 1.0.5 on a mac as well with the same issue. I found a thread with a kind of the same issue and tried wiggling the cables and even unplugged and re plugged all connections. I can see the LB2 but still no M600. DJI is telling me that the A3 has been bricked and to send it to them. They should have a way to manually install the firmware like all the other uavs they have.
2016-11-7
