GPS / GLONASS - AUS vs USA Version
858 5 2016-11-3
SrVdqMFqoqTR
Flight distance : 135689 ft
Hi
Is there any difference in the GPS systems in the USA / Australian versions of the Mavic?
The reason i am asking is because an Ebay seller is saying there is a difference and i just want to quash any misinformation?
From reading the specs sheet on the DJI website there is just one spec & that all Mavics support GPS + GLONASS. Is this correct?
2016-11-3
MattN
Flight distance : 104495 ft
That is correct Mavic supports both US and Russian based GPS...
2016-11-3
interceptorx5
Flight distance : 397 ft
MattN Posted at 2016-11-4 08:20
Strange answer when clearly the OP is asking about Australia.
2016-11-3
fansa66b116d
New Zealand
Agree it didn't answer the question but it's not that strange as he confirmed that the mavic supports GPS (American) and Glonass (Russian).
2016-11-3
Jenee 2
Flight distance : 7852129 ft
interceptorx5 Posted at 2016-11-4 11:30
There is no Australian GPS. All items with GPS use either the US (military) or Russian (Glonass) or both. Each system has a number of satellites and they are used. The best scenario is to have access to both because at ant time, the GPS access can be turned off but the US have now guaranteed they won't shut theirs down because it could have some major implications but you never know.
2016-11-3
Logger
Flight distance : 2883714 ft
There is however a difference in the power lead that connects to the charge brick. You can easily pull it out and swap it with a locally sourced AUS one and then no need for adaptors.
2016-11-3
