hallmark007
Flight distance : 9827923 ft
You don't need to calibrate IMU before every flight, when you get your drone it is a good idea to do it then,
I would make sure you do it on a very flat surface I use a sprit level just to make sure, after completing, you will then be prompted when it needs doing again there are also indicators in the dji go app, to check it.
It's also a good idea to do it if you've had a hard landing or crash.
Compass calibration you should do when and wherever you set up for your first flight, if it's a location or area you are going to regularly fly from you shouldn't need to continually do compass cal. You will be prompted if it needs doing.
If you travel say a distance of more than 50 miles most people would advise doing a compass CAL , and obviously if you take your aircraft overseas.
