Piece needed Ed or Ken
1046 2 2016-11-4
Puttmaster
Flight distance : 18931532 ft
Guys,
I have lost a plastic part and not sure if its even needed or not. It is the platic insert for the P4 arm at the end. Is there a way to get these? Do not want to send it in for just this. Thanks.
2016-11-4
LJPro
Flight distance : 15220 ft
You don't need these plastic pieces, some of the types of prop guards fit into these spots and some fasten another way.... they can all be removed if you like.
2016-11-4
Rodger8
Flight distance : 20145135 ft
As noted above they are removable and the slot is used for the quick removable type prop guards.
2018-3-31
