pink pictures raw files X5)
715 3 2016-11-4
fansbbbfede1
Flight distance : 821768 ft
Hi ,
I did use for the first time the X5 camera ,but now i have pink pictures ,with the x3 no problems at all .i did the adobe raw convertor but still pink pictures in Lightroom and Adobe.
What i am doing wrong here .
greetzz
problem solved ,,something was wrong with the SD card
2016-11-4
DJI-Jamie
Flight distance : 112405 ft
Could you happen to provide a sample picture of what you're getting? Is this with JPG files or DNG? Do you use the X5 Pro or the X5 Raw? Have you ensured you have properly exposed your stills?
2016-11-4
fansbbbfede1
DJI-Jamie Posted at 2016-11-4 19:09
Could you happen to provide a sample picture of what you're getting? Is this with JPG files or DNG?  ...
Thank you for the reply ,the problem is solved ,there was something wrong with the SD card , i reload it again and strange enough everythink is okay  . ANd you are right i could be more specific .. it is the X5 enyway and the problem occurs with raw files . but now everything is (weird) fine .but thank you for replying  .
2016-11-4
DJI-Jamie
fansbbbfede1 Posted at 2016-11-5 04:44
Thank you for the reply ,the problem is solved ,there was something wrong with the SD card , i relo ...
Glad to hear you were able to sort it out. Thanks for the update!
2016-11-4
