Mavic - Tripod mode gone after iOS update
1733 11 2016-11-4
fans7313fddb
Can't find tripod mode after iOS app update... Am I missing somemthing?
2016-11-4
Gary Mac
Flight distance : 741683 ft
I have seen it mentioned that others had it disappear after updating and then came back after downgrading.  Might try going back a version.  Sucks though.  I'd try, but I'm a "waiter".
2016-11-4
fai58
Flight distance : 104439 ft
Tripod mode should still be there.  As I just flown after upgrade my iOS to 10.1.1.
2016-11-4
CkZzoJgcQpSP
Singapore
I have the same issue i can see when its not connected to the mavic, but once its connected its gone. Im using IOS 10.1.1
2016-11-16
Drmerlin
Flight distance : 2441663 ft
I spent the morning struggling to understand why I could not find Tripod Mode on the Mavic... I then discovered that for IOS at least there is now a new app... DJI GO 4... The Mavic flew perfectly well with the original DJI GO app but as soon as I downloaded this I was required to do another aircraft firmware upgrade... Then... lo and behold.... Tripod Mode was available... Hope this helps.
2016-12-2
Drmerlin
CkZzoJgcQpSP Posted at 2016-11-17 07:53
I have the same issue i can see when its not connected to the mavic, but once its connected its gone ...
Make sure that you are using DJI GO 4 and not the original DJI GO app. It is available from the Apple App store....
2016-12-2
Drmerlin
Gary Mac Posted at 2016-11-4 23:26
I have seen it mentioned that others had it disappear after updating and then came back after downgr ...
Are you using DJI GO 4 App or the original????
2016-12-2
Gary Mac
Drmerlin Posted at 2016-12-2 13:35
I don't have mine yet.  I have the Go 4 app on my phone.  Looking forward to seeing if it all works when my Mavic gets here.
2016-12-2
DJI-Ken
Flight distance : 1515312 ft
Gary Mac Posted at 2016-12-2 12:26
I don't have mine yet.  I have the Go 4 app on my phone.  Looking forward to seeing if it all work ...
Make sure to let us know your impressions when you open the box and have your first flight.
2016-12-2
Gary Mac
DJI-Ken Posted at 2016-12-2 15:19
Will do... waiting on the combo!
2016-12-2
DJI-Ken
Gary Mac Posted at 2016-12-2 14:23
Sounds good, thanks.
2016-12-2
Drmerlin
Gary Mac Posted at 2016-12-2 19:26
I don't think you will have any problems. I am thrilled with the Mavic. Got mine on Monday and have had 8 flights and logged about an hour and a half so far.
The only glitch I have experienced was today when, for no apparent reason, the aircraft suddenly switched into Atti mode. Ot was one;y about 300 feet away and was locked on to at least 18 satellites. I started to fly it back to me and it switched back to GPS Mode. I did not have any other problems after that. I note that others have experienced the same thing...
2016-12-2
