Inspire 1 not updating latest firmware
1091 6 2016-11-5
Vernie
Flight distance : 112566 ft
Need help my inspire not uodating to latest firmware v1.9.30 insert sd card to gimball and nothing happen the led light flashing yellow and no sound
2016-11-5
DJI-Jamie
Flight distance : 112405 ft
Is the SD card completely clear with only the .bin file on it? Have you tried reformatting the card and trying again?
2016-11-5
Vernie
Yes sd completely clear and reformatted over 5 times and download the .bin notting happen
2016-11-5
Donnie
Flight distance : 3636782 ft
     Make sure you have the correct firmware, triple check it.  The Inspire 1 will only work with that Firmware , if you have the Pro or Raw you must use that one. Are you using a Mac or PC ?  Macs sometimes dont wipe the whole  file when formatting , use the Aircraft to format  the SD card  and try again.  Use a PC whenever possible for updating.
More than likely the fixes above will take care of the problem .
donnie
2016-11-6
Vernie
Donnie Posted at 2016-11-6 02:58
Make sure you have the correct firmware, triple check it.  The Inspire 1 will only work with th ...
Thank u Donnie bought a new sd card and download the firmware to my pc and finally work and able to update the inspire.
2016-11-6
Donnie
Vernie Posted at 2016-11-6 23:10
Thank u Donnie bought a new sd card and download the firmware to my pc and finally work and able t ...
Cool, glad you are up and running.
donnie
2016-11-7
DJI-Jamie
Vernie Posted at 2016-11-7 13:10
Good to hear, thank you for the update!
2016-11-7
