Jello Effect and Gimble Problem
867 7 2016-11-6
user2e9631e2ff
Experiencing bad jello effect on my P3S. The video is with Polar Pro ND8 filter. Helped jello effect. Still very frustrated at how much footage has been ruined from jello effect and this strange occurrence of the gimbal randomly failing in mid-air.
2016-11-6
Could you please check the vibration absorbers and the propellers if they are damage or not?
2016-11-6
DJI Natalia
Flight distance : 318 ft
If you do not use the Polar Pro ND8 filter, how about the footage? would you mind uploading the video? thanks.
2016-11-6
trumpetpuppet37
DJI Mindy Posted at 2016-11-7 11:36
The Props are new and the shock absorbers are not damaged.
2016-11-20
trumpetpuppet37
DJI Natalia Posted at 2016-11-7 11:42
If you do not use the Polar Pro ND8 filter, how about the footage? would you mind uploading the vide ...
The Jello effect is even more prominent without the filter.
2016-11-20
RedHotPoker
Flight distance : 165105 ft
If not the fault of the "vibration dampers", perhaps you need to balance the rotor props. ;-)
You know those spinning thingies? Chuckles
RedHotPoker
2016-11-20
Geebax
trumpetpuppet37 Posted at 2016-11-21 09:14
Also, check you have not got all four anti-drop pins installed, only two should be fitted.
2016-11-20
Adam Flurk
Flight distance : 425466 ft
Geebax Posted at 2016-11-20 17:30
Great advice. I would also make sure your props came from DJI and are not bought from some 3rd party. Just in case.
2016-11-21
