Lag in response on controller and way point issue
471 2 2016-11-7
fansa015cfc6
Flight distance : 170820 ft
Vietnam
Hi does anyone face issue when you try to increase the height of the P4 it does not response to your command immediately
Currently when in increase the height , the phantom will continue to increase the speed when I put the joy stick to the center .
In addition way point also doesn't work as they request the min height to be 3 m when my actual high is already more than 3 m
2016-11-7
Could you please clairfy the current firmware version of your aircraft and RC?
And what's the DJI GO app version?
Also when you release the stick, the aircraft will not stop immediately. There's a braking process.
Please correct me if I misunderstand your description.
2016-11-7
Richard yue
South Korea
I have upgraded to the latest before I travel before dji 4 is out .
You misunderstood my meaning . My problem is that when I try to rise the height it doesn't response more than 50 m height
2016-12-9
