Recording split after 9min 22 sec or 4 Gb file
702 5 2016-11-7
fans67fa824d
Flight distance : 13051 ft
[size=14.6667px]I have found that during the recording the timer normally flows coming over 15 min. when I go to see the files, I find out that they are separated. a 9 minute file and 22 seconds (about 4GB) and a smaller one that completes the recording. This happens either with MOV files with MP4 files. I checked and the cards are formatted in exFAT system.
[size=14.6667px]Then the recording stops and restarts itself after reaching the 4GB or 9 minutes in 4K / 30fps.
[size=14.6667px]How can this happen ? There's some absurd setap to changing in pilot app?
[size=14.6667px]
[size=14.6667px]Thank you
[size=14.6667px]
[size=14.6667px]Vittorio
2016-11-7
DJI-Jamie
Flight distance : 112405 ft
If you are filming for a long length of time and in a high resolution, then the file will split itsef once the shot exceeds 4 GB. This is a fucntion that cannot be changed, as it is a limitation of the available cameras in combination with the FAT32/exFat format. When the file does split, it would require for you to stitch the footage together in post.
2016-11-7
fans67fa824d
DJI-Jamie Posted at 2016-11-7 19:35
If you are filming for a long length of time and in a high resolution, then the file will split itse ...
thank you very much
2016-11-7
DJI-Jamie
You're welcome.
2016-11-7
nebelung
Flight distance : 613615 ft
DJI-Jamie Posted at 2016-11-7 10:35
All true, except that there usually are a few frames missing between the 2 files.
No idea why that is an issue with DJI products...I don't recall having that problem with any other camera, where the files all stitch seamlessly.
Know it, and work around it.
2016-11-8
unsatisfied
2016-11-8
