Henry M.Y.
Flight distance : 11548839 ft
Hi JH3,
No indication on max allowable in-use battery temperature can yet be found relating to the Mavic Pro from any of the manual, safety guidelines nor official DJI web site. We may, however, make reference to the Inspire 1 battery and Phantom 3 battery to get some clues, because all these batteries are adopting similar Li-Po chemistry. The core temperature of the battery can be accessed from the battery status page in the DJI GO App. Remember, it is absolutely normal for a battery getting warmer than the ambient temperature when in use.
Inspire 1 TB47 battery operable ambient temperature -10 deg C to 40 deg C; max in-use battery temperature 71 deg C; battery chargeable temperature range 0 deg C to 40 deg C.
Inspire 1 TB48 battery operable ambient temperature -10 deg C to 40 deg C; max in-use battery temperature 71 deg C; battery chargeable temperature range 5 deg C to 40 deg C.
Phantom 3 PH3 battery operable ambient temperature -10 deg C to 40 deg C; max in-use battery temperature 71 deg C; battery chargeable temperature range 0 deg C to 40 deg C.
Mavic Pro FB1 battery operable ambient temperature -10 deg C to 40 deg C @ Mavic Pro battery safety guideline (5 deg C to 40 deg C @ DJI web site); max in-use battery temperature ?? deg C; battery chargeable temperature range 5 deg C to 40 deg C.
In HK, ambient temperature in a summer day usually goes up to 33 deg C, with Inspire 1 Pro's TB48 in-use battery temperature often reaches up to 62 deg C. No significant degrading of battery has been noted so far.
Given the small size of the Mavic Pro hence faster heat dissipation, even with a high ambient temperature of 40 deg C one can hardly push the Mavic Pro to such a state with a battery core temperature close to 71 deg C.
Henry
