D-RTK Antenna Offset Parameters on the M600
2343 1 2016-11-7
alex_cape
Flight distance : 61047 ft
Hello all,
Looking for the correct offset values for the D-RTK antennas when using the M600 mounting kit. The tutorial video (linked below) shows xyz values of 160, 0, -180 and -160, 0, -180 for ANT1 and ANT2, respectively. This can be seen at 4:53 in the video. Are these values correct? Where is the reference point for the D-RTK parameters, the CG or center of the A3 (assuming that they are not the same)? Where are we measuring to on the D-RTK antenna, the bottom face?
Just a bit curious as to what has worked for others and if DJI has official numbers to use.
Thanks!
2016-11-7
Leofuica
Flight distance : 1107146 ft
Chile
Hi, if you keep in mind the original gps setup need add 3cm to both hight, and the results is 217mm and -217mm
2016-12-7
