fansffceb00f
Brazil
Hi, I know that the DJI Focus is a perfect match to use with Ronins, but when not using with a Ronin you have to use the D-Tap-Lemo cable for the Motor and plug it to a V-Mount battery (waaaay heavy and overkill for this purpose) or use a V-mount and a cheeseplate with D-tap feeding all your devices (camera, focus motor and monitor). But sometimes I don't want to have all this (A V-mount battery, a V-mount plate and a bunch of cables around).
It would be perfect to have a very small battery with a 90º Lemo that just plugs to the motor in order to make things neatier.
A, not so good workaround, is to use a D-tap Female to USB or something like this, but even this I couldn't find a solution ready, I would have to make one.
Is there anyone that found a solutions to this?
The other thing is that the motor is turning on the rails even when I tighten very snugly. Sometimes the torque itself pushes away the motor.
I've lowered the torque on the "motor param" but it keeps happening.
Is there any solution for this?
Regards,
