Just got drone back AGAIN
1181 18 2016-11-9
fans111d956a
Now it wont load the new firmware.... I reset it back to factory and loaded the one from a month ago on fine...So is this on their end or is something wrong with the drone?
2016-11-9
Cetaman
Flight distance : 2528264 ft
Aloha fans111,
     You have to increase the firmware step by step.  Hope this helps!
Aloha and Drone On!
2016-11-9
DJI Natalia
Flight distance : 318 ft
May I know you have upgraded it to the latest one successfully? if no, any error messages popping out when doing that?
2016-11-9
ShannonGTO
DJI Natalia Posted at 2016-11-10 11:02
May I know you have upgraded it to the latest one successfully? if no, any error messages popping ou ...
It just says I need to upgrade to the one released a couple days ago...It says it can't download the new firmware but does the old one...
2016-11-10
DJI-Jamie
Flight distance : 112405 ft
Can you verify what firmware the Assistant 2 says is on the unit? What version of the Assistant 2 software do you have?
2016-11-10
ShannonGTO
DJI-Jamie Posted at 2016-11-11 08:17
Can you verify what firmware the Assistant 2 says is on the unit? What version of the Assistant 2 so ...
Version: 1.0.4
DJI Assistant 2
2016-11-10
DJI Natalia
ShannonGTO Posted at 2016-11-11 09:23
Version: 1.0.4
DJI Assistant 2
Would you please download the latest Assistant on the website (V1.0.6): http://www.dji.com/phantom-4/info#downloads
And please check your current firmware version on "About" page through APP?
BTW, what mobile device you are using to connect the remote?
2016-11-11
DJI-Jamie
Version: 1.0.4
DJI Assistant 2
Like Natalia stated, you're not using the latest Assistant 2 version. When you install the latest 1.0.6 Assistant 2 software, then you'll be able to see the latest firmware.
2016-11-11
ShannonGTO
Ok just loaded new firmware... all good... I reset it and decided to do a calibration and it let's me complete it but it gets stuck in the "calculating" part and stays at 0%
2016-11-11
comnick62
Today I installed the latest firmware on my P4. I tried first with Assistant on my mac but after the download did not start the installation. So I decided to install it with DJI GO. All good up to 95% of installation then appeared two errors. I told him to continue, and in the end I became a successful installation message successfully. Tomorrow I will make a test flight.
2016-11-11
ShannonGTO
Its all installed...The calibration part hasn't effected it as it flys fine and warns me of objects
2016-11-11
DJI-Jamie
ShannonGTO Posted at 2016-11-12 06:03
To clarify, what mobile device are you using and which Go app version are you running?
2016-11-11
comnick62
DJI-Jamie Posted at 2016-11-12 02:40
I use ipad pro and GO version 3.0.2
2016-11-12
DJI-Jamie
comnick62 Posted at 2016-11-12 20:52
And this is occurring even after a factory reset via the Assistant as well? Could you happen to try using an Android to see if you get the same error messages?
2016-11-12
ShannonGTO
DJI-Jamie Posted at 2016-11-12 09:40
IM using a Galaxy Note 5...I have had ZERO problems with it with the previous P4...
Im running version 3.0.1 on the DJI GO
2016-11-13
ShannonGTO
No response?
2016-11-16
DJI-Jamie
Have you tried using the latest 3.1.0 Go app to see if you're able to calibrate properly?
2016-11-18
ShannonGTO
DJI-Jamie Posted at 2016-11-19 06:08
No but I will and will let you know
2016-11-18
DJI-Jamie
ShannonGTO Posted at 2016-11-19 10:49
Please let me know when you can.
2016-11-18
