DJI Mavic Loses Connection and Disables Vision Sensors?
1819 7 2016-11-9
JordanM
Is this true that when you lose signal with the remote the vision sensors are disabled?
I find this hard to believe that this Mavic just ran into the tree while returning to home. It did not even ascend like it is supposed to unless it already thought it was high enough if it took off from a lower elevation.
2016-11-9
FlameBoy
Flight distance : 105558 ft
Looks like the drone tried to return home with the hight that was set by the user hense why it decended then turned.
2016-11-9
JordanM
FlameBoy Posted at 2016-11-9 15:00
Looks like the drone tried to return home with the hight that was set by the user hense why it decen ...
Ya thats why i was questioning him about the RTH altitude and he said probably around 150 feet. Doesn't sound like he was to sure though. Do you know if the visions collision sensors are turned off on RTH when loosing signal?
2016-11-9
Eagle-i-AL
Flight distance : 3572106 ft
JordanM Posted at 2016-11-9 15:06
Ya thats why i was questioning him about the RTH altitude and he said probably around 150 feet. Do ...
This is from the manual. If i remember correctly, I had to go into the settings and enable the Forward Vision System and also increased the default rth of 30m.
"The aircraft cannot avoid obstruction during Failsafe RTH if Forward Vision System is disabled. It is important to set a suitable Failsafe altitude before each flight."
2016-11-9
hallmark007
Flight distance : 9827923 ft
JordanM Posted at 2016-11-9 20:06
Obstacle avoidance should still work with RTH even if you loose signal.
2016-11-9
hallmark007
He just flew straight into tree,
2016-11-9
Jeromeo
Flight distance : 103369 ft
JordanM Posted at 2016-11-10 04:06
No they are not disabled  . But if you are in sport mode you have no colision sensors. SO maybe it's what happened.
2016-11-9
JordanM
Ok that is what i thought. I Upped my RTH from 30m to 50m right away and turned on the vision sensors. They have been working really good.
2016-11-9
