Panamedia
Good Morning!
I have a problem with an A2 + Sky Hero X4 700, the drone flies but is very "irregular".
Flying in translation the drone tends to falls rapidly (4/8 meters) and then recovers again. I tried vertical gain from 90 to 400% but didn't changed.
When you start the movement (mainly lateral) it sounds that the FC removes power and when you moove the stick a little it "awakes" and stabilizes, otherwise it keeps falling as it's not realizing is slowly falling.
I've tried changing the "Advanced gains" and it changes but I do not know what I am really changing.
Could somebody please explain them for all of us?
Extra: I have also a problem with the LED, has NO LIGHT at all. It's connected to the drone because I can use the Assistant with the USB.
Thanks very much in advance.
Equipment:
Sky Hero
Lightbridge 2
A2
T-Motor U5
T-Motor16X5.4 Props
Regards
Pedro
