DA5neRJlpKOZ
Flight distance : 458944 ft
Hello,
I updated to the *0900 firmware yesterday and experienced the same issues (freeze at 99%, lower port locked out when cable connected to upper port) others are experiencing.
At this point, everything seems OK. Both the controller and aircraft report that they are using the *0900 firmware and I understand the interaction between the ports and can get the mobile app to work on the lower port.
However, during the confusion I tried refreshing, downgrading, and resetting to factory defaults with the remote and none of them worked. At this point I no longer want to do any of those things, but I am worried that the fact that I couldn't will be a potential problem in the future.
Is there some trick I don't know. Here's how I was trying ot use it:
1) I was using DJI assistant 2 on a macbook.
2) the remote was connected to the macbook via usb to the upper port on the controller.
3) I turned on the controller and DJI assistant 2 saw it and showed me that the firmware version was *0900 and offered options to refresh, downgrade, and reset to factory default.
4) Choosing to refresh or downgrade gave me a progress bar which stayed at 0% and eventually timed out with an error.
5) Choosing to reset resulted in an error after only a few seconds.
Should that have worked? Should I be worried that if I need these features in the future they won't work for me?
Any insight appreciated.
Thanks,
Larry
