Help please !
Simo1
Hello,
I have a question for you, I would like buy a new phantom and the problem is that I can't use my left hand because I have a problem.
Do you think is easy to use the drone with one hand or is it complicate?
thanks
Simone
2016-11-10
Gerardo Rejec
Flight distance : 120141 ft
I know for a fact you can control the drone with just one hand using your thumb and ring finger.  The only problem you might find is that you will need to place the controller on a label surface like a small table or something
2016-11-10
Simo1
Gerardo Rejec Posted at 2016-11-11 03:13
I know for a fact you can control the drone with just one hand using your thumb and ring finger.  Th ...
thanks to replay, I will try.
2016-11-10
Matt-and-Riley
Flight distance : 324442 ft
At 5:00 there's a guy with 1 arm racing quads
2016-11-10
Simo1
Matt-and-Riley Posted at 2016-11-11 04:26
https://youtu.be/TClOCky3xEI?t=5m
thank you, it is very interesting for me
2016-11-10
Cetacean
Flight distance : 2528264 ft
Simo1 Posted at 2016-11-10 10:48
Aloha Simo,
     There is also a belt that you can use with the neck strap.  It holds the controller level in front of you.  I use one on occasion.  It is a re-purposed utility bag (laptop bag) strap with clips on both ends.
     But they do sell dedicated controller belts at Hoodman;
https://hoodmanusa.com/cgi/comme ... n&category=0060
Not cheap but it works.  Still good to have the strap around the neck along with the belt.
     Hope this helps!
Aloha and Drone On!
2016-11-10
Simo1
Cetacean Posted at 2016-11-11 04:58
Aloha Simo,
     There is also a belt that you can use with the neck strap.  It holds the control ...
THANKS !! It will be helpful for me..
2016-11-10
DJI-Jamie
Flight distance : 112405 ft
Best of luck to you.
2016-11-11
Kneepuck
Flight distance : 275105 ft
Simo1 Posted at 2016-11-10 16:09
You are able to change the way the control sticks work,  ie: mode change, so you can try different settings to see what works best for you as well
2016-11-12
