Cameras : Did you know ?
1877 12 2015-2-8
dundee
Flight distance : 33550 ft
Thailand
Really interesting video on how a camera shutter/mirror works
2015-2-8
dundee
Thailand
Camera and gimble are hanging under the inspire with 4 small rubber dampers.
If something go wrong with these dampers, the gimble and camera can drop down.
I slipped a small size cable-tie thrue the hole of the 2 front dampers. (not tighten).
I did not cut the excess yet, so its better to see on the picture.
I dont think it will interfere with the gimble operation.
I did not test this as im still waiting for the prop locks.
Good idea ?
2015-2-8
GB44
Flight distance : 343848 ft
Nice Video and good idea with the zip ties.  I have done similar using braided 22lb breaking strain line used as backing line in fly fishing to connect my GoPro filter to the Phantom just in case that wiggles loose in flight.
I was also informed on my BNUC course by the instructor that any payload should have two means of mechanical connection to prevent it falling off in flight.
2015-2-8
dundee
Thailand
Gimble & camera is a payload on the Inspire1. So your instructor would give me max points on this ?
2015-2-9
johnmont250.ema
looks to me like the rigid plastic will induce more vibration=jello.
2015-2-9
dundee
Thailand
johnmont250.ema Posted at 2015-2-10 01:15
Yes, was thinking about that. WIll make the tests soon.
I think a question of giving it enough slack.
Maybe fish-wire better. But i cant make knots uhhh.
2015-2-9
daver/m
Flight distance : 206503 ft
Did this on my phantom 1.1 two years ago before dji came out with the plastic keepers ,didn't want to loose the new zenmuse gimble and Gopro I'd purchased , that gimble originally cost $700.00 + and came separate...  Strange DJI didn't think about those safety keepers on the inspire hmmm....
2015-2-9
T J Gilbert
Flight distance : 74659 ft
daver/m Posted at 2015-2-10 01:53
Did this on my phantom 1.1 two years ago before dji came out with the plastic keepers ,didn't want t ...
I used loose, 4" wire-ties on my H3-2D gimbal when it was state-of-the-art.
It never posed a problem.
I might consider this on the I1.
A concern...
I've read of a few crashes where the cam/gimbal were saved because they popped off.
If tied down, it might cause more damage...
2015-2-9
daver/m
T J Gilbert Posted at 2015-2-10 03:02
It never posed a probl ...
I'd agree anything might happen and the phantom was a little bit differnt than the inspire after examining the grommets and cables ....
2015-2-10
chato1974.gmail
Flight distance : 2630909 ft
dundee Posted at 2015-2-8 17:55
If something go wrong w ...
Most pilots if they're worried about loosing the gimbal and camera to a fall tie loosely double looped dental floss with two box knots and trimmed tight exactly where you put your zip ties. The dental floss is extremely strong and very light.
2015-2-10
dundee
Thailand
chato1974.gmail Posted at 2015-2-11 15:01
Most pilots if they're worried about loosing the gimbal and camera to a fall tie loosely double lo ...
good idea too
2015-2-11
GB44
I have used braided fishing line to provide secondary mechanical fixing.  You can get it in various breaking strains.  The one I use is rated 22b ( 10kg) breaking strain and is about the same diameter as dental floss.  Just burn the ends slightly with a lighter to seal it whenever you cut it.  I think you can get super braid backing line up to 76lb (35kg) breaking strain.  All available at fishing shops and on line.  Just serach for braided backing line.
The differenece is it is flexible like string not like the rigid zip ties, although these are great.
2015-2-11
dundee
Thailand
GB44 Posted at 2015-2-11 17:48
I have used braided fishing line to provide secondary mechanical fixing.  You can get it in various  ...
I go for the fishing line.  thanks mate
2015-2-11
