Donnie
Flight distance : 3636782 ft
Look inside the boot of the Servo motor that lowers and raises the gear, make sure no bit of gear are getting chewed up in there , if it looks ok add just a bit of 3 -1 oil or sewing machine oil , NOT WD -40. also add just a touch of oil at all the hinge points on the outriggers and booms where it twists during movement .
This should fix it as long as it is not out of gear mesh and just a tad dry on the joints and gear.
**** I did read it when you said it is lubricated, just make sure the booms and riggers get some oil also , any joint that moves with the landing gear going up or down lube , check for anything being to tight also that may need adjusting .
donnie
