MAVIC DLOG sucks?
3445 7 2016-11-13
LostinJapan
Japan
Hi everyone,
From excellent Casey Faris, he analysed footages on different types:
Any feedback from Mavic users would be great:
-2.7k better results than 4k?
-Art better than DLog?
What are your settings?
Thanks
2016-11-13
henk0
The last FW changed also the color profiles. So D-LOG ist good again? Or still recommended to use art?
2016-11-13
chanley380
Flight distance : 75659 ft
dlog doesn't suck...but it does look like shit upon initial playback, (whaaaaaaaaaat?...I paid all this money, it should just look awesome!...well...yes and no.). Also, you won't be able to see much, in bright sunlight, on the display attached to your RC.  Dlog is pretty much a raw/untouched/what the camera sees/flat format.  With that said, it captures ALL the color data...which means that it can be adjusted/color graded later in post.  this is a good thing. read more here. http://www.phantompilots.com/thr ... ults-awesome.69672/
I do think it's a little unfair to the product to be conflating "video quality" with "color correctness".  That's like saying my super fancy DSLR takes crappy pictures at night...when I really don't know how to adjust the camera settings properly.
2016-11-13
method007
Flight distance : 110449 ft
chanley380 Posted at 2016-11-13 16:21
dlog doesn't suck...but it does look like shit upon initial playback, (whaaaaaaaaaat?...I paid all t ...
What he said.
2016-11-13
leostark
it shouldn't if you know how to color grade, otherwise yeah, it would look washed out cz that's how the camera sees {:4_177:}
2016-11-13
yoengel
Flight distance : 1959259 ft
chanley380 Posted at 2016-11-14 06:21
Can you do color grading in Final Cut Pro X?  What do you recommend?
2016-11-13
grozmo
I'm not convinced by turning the sharpness down "in mavic".. that can easily be done post, right? I never set cameras to do in-camera post processing. (eg. I don't shoot with black and white setting on my camera - easily done in post and still have the original image).
2016-11-13
C_LUU
Flight distance : 481988 ft
grozmo Posted at 2016-11-14 08:56
I'm not convinced by turning the sharpness down "in mavic".. that can easily be done post, right? I  ...
Its the other way round, you can always add sharpening in post production but you cant remove it, that is why its recommended to turn sharpening down to avoid common aliasing you see in a lot of P3/P4 videos. Particularly when you are down scaling 4k to 1080p. I have not shot with the Mavic, only Phantoms, but DJI cameras are known for having standard sharpness setting too high. I always shoot with sharpening at -3 and add some sharpening in in post.
2016-11-13
