Do I need bluetooth enabled on my phone?
5808 14 2015-2-8
dchicora.comcas
Hello all.  Noob question here.  I am new to all this stuff and just recently purchased the P2V+.  I keep seeing references of bluetooth to this machine in my scouring of the internet to figure stuff out but nothing definitive about bluetooth.
My question is, "Do I need bluetooth enabled on my phone or tablet in order to use the groundstation app?"
Like I said, I keep seeing vague references about bluetooth but nothing definitive.
Thanks.
2015-2-8
Capt. Bill
I believe you can convert to Bluetooth for more range but basic set up is WiFi
2015-2-8
dchicora.comcas
Ok.  Thank you.
2015-2-8
Tahoe_Ed
Flight distance : 2605 ft
Please turn BT off and put your phone in Airplane mode.  You want to avoid potential interference.
2015-2-8
Capt. Bill
Bluetooth will run you phone battery down faster. I don't have to put mine in Airplane mode and have stayed connected with Bluetooth enabled for an hour. As I mentioned before having the  AT&T Smart WiFi app enabled caused my WiFi to switch after 3 minutes every time. I guess because it was "smart" it switched me to a connection with internet access.
2015-2-8
SAFrankSU
I've got a Phantom 2, but I never need to use BT. Some say to put your phone in airplane mode and I probably recommend doing that. I don't (but probably should). I do however turn off any applications I might have open on my phone.
2015-2-8
johnwarr.live
Flight distance : 6467 ft
The Vision app connects to the Wi-Fi range extender on the transmitter, it does not use Bluetooth, so no, you do not need it turned on.
2015-2-8
Capt. Bill
Anyone know what happens if you get a call on your phone while connected?
2015-2-8
johnwarr.live
Nothing, just answer it, or not, and return to the app.
2015-2-8
dchicora.comcas
Thanks for all the replys.  Some good info to know.
2015-2-12
teedo757
Flight distance : 1870 ft
Capt. Bill Posted at 2015-2-9 01:00
Bluetooth has very limited range. Your gonna want to wifi antenna upgrade or amped up extender to get more range.
2015-2-12
teedo757
2015-2-12
Northofthe49th
Capt. Bill Posted at 2015-2-9 08:51
I've never had one as I fly in Airplane mode and then I enable Wifi, forget the other networks that show up and only have the Phantom available as a network and I have Bluetooth turned off..
Basically eliminate as much chance for any interference as I can.
2015-2-12
teedo757
From a technical standpoint Bluetooth and Wifi B/G/N operate in the range of 2400–2483.5 GHZ. Remember on the phantom vision series the 2.4 is used ONLY for the video/data feed. The higher wifi 5.8 GHZ is more important as it is the controller frequency. Getting a call will stop your video feed but you will still be able to fly.
2015-2-12
mixstreme
Tahoe_Ed Posted at 2015-2-9 08:22
Wi-Fi connection will also die in airplane mode......   dynamic home point?    etc...
2015-2-12
