Donnie
Flight distance : 3636782 ft
Sure does . Keep in mind the auto landing gear will only come down ONE time per flight , after that you must do it manually with the RC flipper button .
when you go into travelmode , youhave the camera removed and you are on a hard level surface correct ? because the VPS sensor is what tells the Unit how high to bring the "Gear , if it is damaged ( VPS ) then it can not do the function correctly .
Does the VPS give good data when at 10 feet and below ? If Not the unit is damaged.
The VPS is the Ultra sonic sensor , if it is not giving good data from 10 feet down toTerra Firma ( earth ) , it is bad or the cable going to it or connector .
donnie
