Donnie
Flight distance : 3636782 ft
Smart RTH is just an automatic RTH when the battery gets to a predetermined point to make it safely back to the Home Point . Do not always rely on this calculation to be correct as a headwind on the Return Home trip could be fatal to the aircraft .
RTH covers several areas but have the same basic funtion : get the aircraft back to the Home Point . ALWAYS listen for the announcement " Home Point Recorded " before taking off. it is a good habit to make sure the volume is way high anbd also you can Hear any other warnings as well.
RTH will also be initiated if you loose control signal for 3 seconds and if you lose video for 6 seconds . The FASTEST way to cancel a RTH is to press the RTH circular button on the remote .
Also RTH will not be initiated with 20 meteres from the Home point if you are just outside of the circle and the RTH is initiated it will climb to a specified altitude and begin the trip back home , cancel it immediatly if you dont want this to happen as you have limited control of the ascent once the process begins .
Make sure the RTH will be higher than any obstacle in you area but no higher , usually when RTH is initiatetd you are low on power anyway , dont waste it by having a ridiculusly high RTH setting , it will only drain the battery more than necessary.
The Yaw endpoint is realy a stupid way of describing its function . What this does is slow down or speed up the Yaw of the Aircraft .
[size=14.6667px]Yaw end point controls the top speed of the drones yaw. Think of the values of 100-150 as 100% to 150%. So you can increase the top speed of the drones yaw by 50% or thereabouts. You want a nice slow pan when shooting video but when hot dogging you may want to max out the Yaw speed .
Long press action ? What model are you referring ? The only thing I can think of is when you press ( and hold ) the screen of the Go app you take control of the cameras gimbal as to where the camera is looking , it will turn into a green circle and you can point the camera where you like .
I sure hope this helps you.
donnie
