Home wifi cuts out
893 5 2016-11-15
tgs3838
Flight distance : 213957 ft
Hello everyone. Maybe this is a dumb question. But i did a quick google  search and couldn't find anything. But every time i turn my drone on  inside my house my wifi cuts out. Seems like i remember reading that the  drone runs off the same frequencies(not a computer expert so forgive me  if im wrong) as the wifi? Not that its a huge deal i guess. But i was  wanting to watch some youtube videos and try to get some tips for the  camera settings and stuff like that. And i don't believe you can change  the setting without the drone on. But is there anyway around this? Or  just something i have to deal with? Thanks.
2016-11-15
fans4247cd6d
bump... It does the same thing here at home, why?
2016-12-3
Nees
Flight distance : 80991 ft
Belgium
Because it is using the 2.4Ghz band, just like your wifi. Because it is more powerfull then your router, it "screams" louder on the same band, so your other devices don't hear the wifi singal anymore.
This is quiet normal. On custom firmware, you can boost your wifi signal (TX Power) so you can annoy your neighbours, but yourself, have a more powerfull connection and more speed. Because the drone is on the same band but has a much more powerfull output (ever seen your wifi connection at 7KM?) it just "blocks" your wifi.
2016-12-3
fans4247cd6d
Nees Posted at 2016-12-4 02:28
Because it is using the 2.4Ghz band, just like your wifi. Because it is more powerfull then your rou ...
Is there a way to overcome this?
2016-12-4
dotfiles
fans4247cd6d Posted at 2016-12-4 07:36
No it is an inherent issue because the Mavic uses the 2.4ghz band for RC. If your router has a 5ghz option you should still be able to see that signal while the Mavic is in use
2016-12-4
fans4247cd6d
dotfiles Posted at 2016-12-4 09:59
No it is an inherent issue because the Mavic uses the 2.4ghz band for RC. If your router has a 5gh ...
Allright, thx guys.
2016-12-4
