Vision +
664 1 2016-11-15
Tom.Bordenave
Anyone having trouble with certain batteries not allowing the Phantom compass to calibrate ? This is a very inconsistent problem, sometimes it will start up right after calibration and other times I have to reset multiple times to get it to start. I am assuming that it is a compass calibration problem. It won't start if the compass isn't calibrated...right ?
2016-11-15
Harbourside
Flight distance : 6467 ft
What LED's do you get when you try to start and it fails ?
Not sure about the compass calibration causing non start, but I guess it makes sense. Not a fan of doing the calibration, done my V+ no more than twice in 2 1/2 years of ownership.
When hooked up to the PT2 assistant you can check the compass values and look for any warning messages.
The only other thing to check is the 2 small pins for the battery contacts, make sure they are clean and the pads on the batteries.
Good luck
2016-11-16
