Battery and other accessories.
682 8 2016-11-15
MM55
Flight distance : 628527 ft
I know the P4Pro's battery has a higher capacity but will the old batteries still work? What about prop guards, lens filters etc.?
2016-11-15
Aardvark
Flight distance : 384432 ft
http://forum.dji.com/forum.php?m ... D368%26typeid%3D368
2016-11-15
Hi, P4P battery and propellers are compatible with P4.
P4 ND filters are not interchangeable.
The prop guards for P4P can be used on P4 but P4 prop guards cannot be used on P4P.
2016-11-15
Streetmagus
Flight distance : 1398376 ft
My question is the opposite.
Can you use the new higher capacity (P4P Battery) in a normal P4? If so, how much longer flight time can we expect?
2016-11-15
fans4d4455ae
Romania
Streetmagus Posted at 2016-11-16 09:43
Can you use the new higher capacity (P4P Battery) in a normal P4? If so ...
Yes you can and they have a 30 minute flight time.
2016-11-16
rodger
Flight distance : 15812070 ft
DJI Mindy Posted at 2016-11-16 02:40
The pr ...
Will the P4P prop guards disable the collision avoidance system like it does on the P4?
2016-11-16
Jcostello
Flight distance : 1861490 ft
fans4d4455ae Posted at 2016-11-16 10:57
Mmmmmmmmmmmmmmmmmm seing is believing on that one
2016-11-16
rodger Posted at 2016-11-16 19:55
It will not disable the avoidance system.
2016-11-16
rodger
DJI Mindy Posted at 2016-11-16 22:50
Thank you, I thought that would be the case due to the location of the sensors on the P4P.
2016-11-18
