X5R V X5S
9141 11 2016-11-17
DroneAlps
Flight distance : 2043307 ft
What are the main differences and which camera is 'better'?
2016-11-17
ge0se
Flight distance : 3184721 ft
If it isn't as noisy as X5R is then it is MUCH better! Will wait and see.
2016-11-17
Farnk666
Flight distance : 1711394 ft
Doesn't really matter as a comparison. You can't switch between the two on the same bird.
It's a case of I1 vs I2, and that's a much bigger debate.
2016-11-17
DroneAlps
Farnk666 Posted at 2016-11-17 21:38
It's a cas ...
It does matter because why else would someone upgrade from using the X5R to using the X5S?
2016-11-18
DroneAlps
DJI Mindy Posted at 2016-11-18 08:13
The Zenmuse X5S now supports more profession lenses.
The sensor has been upgraded.
And X5S capable o ...
The X5R cannot capture CinemaDNG video and Apple ProRes video?
So what is the difference between the sensors?
2016-11-18
Farnk666
DroneAlps Posted at 2016-11-19 01:00
My point being that because there isn't any backwards compatibility between the I1 and I2 - the comparison is actually between the I1 / X5R and the I2 / X5S.
That takes many other factors into the mix, as well as the basic IQ aspects.
It's not a question of upgrading a camera as such, its a question of "do I replace my current bird or not?"
2016-11-18
DJI-Jamie
Flight distance : 112405 ft
DroneAlps Posted at 2016-11-19 01:02
So what is the difference between  ...
You can find some comparison images on the X5S product page:
http://www.dji.com/zenmuse-x5s
2016-11-18
DroneAlps
DroneAlps Posted at 2016-11-18 18:02
I'll ask this again, can the X5R not produce ProRes in post? Is it just the in-camera processing to ProRes that is new in the X5S?
2016-11-23
DroneAlps Posted at 2016-11-24 09:19
I'll ask this again, can the X5R not produce ProRes in post? Is it just the in-camera processing t ...
X5R cannot capture ProRes. It can shoot RAW, and use Cinelight to convert the file to ProRes format.
But X5S can capture ProRes directly.
2016-11-24
fans478a7e45
Flight distance : 233474 ft
DJI Mindy Posted at 2016-11-24 09:24
X5R cannot capture ProRes. It can shoot RAW, and use Cinelight to convert the file to ProRes forma ...
I think you have to purchase the keys to use ProRes and Cinema DNG which is another £1500! so better add those to the bill as well as the big SSD card at £909 each oh and a reader for the PC at £159 wow this inspire 2 is going to cost £8K in no time.
I thought ProRes and Cinema DNG were open source?
2016-11-24
DroneAlps
DJI Mindy Posted at 2016-11-24 10:24
Right, so both capture RAW - the only difference is that the X5S can do the ProRes conversion in-camera, whereas the X5R would need a computer...?
2016-11-24
ThePhantom
Norway
You can transcode h264 to prores also if you like, in post.
On board prores is not converted, it only records straight to prores, a raw compression if you like.
But what kind of raw format does the X5R shoot in, DNG?
2017-5-1
