Question
697 7 2016-11-17
fans9a7c0aa0
Flight distance : 8327 ft
I don't understand the difference between the forward and rearward facing cameras and the Infrared sensing system. Can someone explain this to me?
2016-11-17
Aardvark
Flight distance : 384432 ft
This must be on the P4 Pro.
These cameras are mounted on the legs front and back, and along with the infrared sensors at the side give the P4 Pro all round Obstacle Avoidance capability.
These sensors are completely independent of the main imaging camera which plays no part in Obstacle Avoidance.
2016-11-17
DJI-Ken
Flight distance : 1515312 ft
The above post is pretty much it.
Cameras front and rear (bottom too) and infrared on the sides.
Here's the specs  http://www.dji.com/phantom-4-pro/info#specs
INFRARED SENSING SYSTEM
Obstacle Sensory Range        0.6 – 23 ft (0.2 – 7 m)
FOV        70° (Horizontal), ±10° (Vertical)
Detection Frequency        10 Hz
Operating Environment        Surface with diffuse reflection material,
and reflectivity > 8% (such as wall, trees, humans, etc.)
VISION SYSTEM
Velocity Range        ≤31 mph (50 kph) at 6.6 ft (2 m) above ground
Altitude Range        0 – 33 ft (0 – 10 m)
Operating Range        0 – 33 ft (0 – 10 m)
Obstacle Sensory Range        2 – 98 ft (0.7 – 30 m)
FOV        60°(Horizontal), ±54°(Vertical)
Detection Frequency        10Hz
Operating Environment        Surfaces with clear patterns and adequate lighting (> 15 lux)
2016-11-17
fans5999632e
Flight distance : 288353 ft
Trying to film with those cameras can lead to disappointment
2016-11-17
FeariTself
Flight distance : 195151 ft
fans5999632e Posted at 2016-11-18 07:41
lol
I'm excited for the increased speed in obstacle avoidance mode.
2016-11-17
Geebax
FeariTself Posted at 2016-11-18 10:45
lol
Yeah, but don't forget it does not see everything, and don't rely on it to work at that speed.
2016-11-17
fans9a7c0aa0
Thank you, DJI but I sill don't understand the purpose of the infrared sensors. Why not just put cameras all the way around it and on top to get 360 degrees of obstacle avoidance.
2016-12-14
fansb1fe1104
Flight distance : 3372566 ft
fans9a7c0aa0 Posted at 2016-12-14 10:24
That will be on the Phantom 5 pro{:4_142:}
2016-12-14
