Gimbal clamp
3840 10 2016-11-17
Bobbybee
Remember when you remove the camera protector (glass bubble) there is also a gimbal clamp (clear plastic) that you need to remove before powering up the drone. The clamp sits behind the camera and to remove it you slide it out. This clamp  holds the camera in position whilst you transport your drone. It's easy to remove and easy to replace when you have finished flying.
2016-11-17
MHM1170
Good Advise
2016-11-17
David Pumpkins
very good advice
2016-11-17
Here is the video tutorial for your reference.
2016-11-18
watuse
Flight distance : 2064587 ft
DJI Mindy Posted at 2016-11-18 16:55
https://www.youtube.com/watch?v=hnXekYjEJA8
why you have to put it in that clamp that he shows after he took the back plate gimbal holder is that how the gimbal comes from factory
2016-11-18
thebmallory
Flight distance : 50466 ft
carefull in that video the gimbal clamp is not properly mouned (@ 0:16) !  Inside the clamp there's two plastic thingy that you have to put inside the space just before the motor that holds the camera... I'll try to make a video or a photo later today to explain myself...
2016-11-18
watuse Posted at 2016-11-18 17:11
why you have to put it in that clamp that he shows after he took the back plate gimbal holder is t ...
Yes it is. Please follow the video to check your Mavic.
2016-11-18
Wind Junkie
Flight distance : 116165 ft
Can anyone advise on putting back on the Gimbal clamp? I can't quite figure out how to do it correctly and I don't like poking around at the gimbal, I feel like I may damage something. Thank you
2016-11-18
thebmallory
DJI Mindy Posted at 2016-11-18 09:55
I'm positive the gimbal clamp isn't properly mounted in the video @0:16 !
here's how to properly mount it (featuring some very french accent ) :
2016-11-18
Wind Junkie
thebmallory Posted at 2016-11-19 02:44
here's how to properly m ...
Thank you! This reference worked excellent. I wasn't securing it tight, but after trying a few times I got it. Thanks again!
2016-11-18
videoguy
Wind Junkie Posted at 2016-11-18 14:06
Thank you! This reference worked excellent. I wasn't securing it tight, but after trying a few tim ...
Add a piece of red ribbon to the clamp because you will forget to remove it.
2016-11-18
