DJI go App no more for iPhone 5 ?
13544 29 2016-11-18 03:53:15
Satstream
Flight distance : 70897
The latest update for DJI go is no longer compatible with iPhone 5! Why are the DJI's customers pushed so hard? Incredible..
2016-11-18 03:53:15
DJI Natalia
Flight distance : 97
Satstream, since iPhone 5 is not in DJI recommended devices list, we could not guarantee it's performance.
It's recommended to use a mobile device which is compatible with DJI GO APP.
IOS: iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPod touch 6, iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei Mate 8, Nubia Z7 mini, SONY Xperia Z3, MI 3, MI PAD
2016-11-18 04:04:08
Satstream
DJI Natalia Posted at 2016-11-18 13:04
Satstream, since iPhone 5 is not in DJI recommended devices list, we could not guarantee it's perfor ...
And what about user Pmarten8? He has an iPhone 5S and it does not work. He posted it under discussion!
2016-11-18 05:04:33
Hummingbird.UAV
Flight distance : 1535251
DJI Natalia Posted at 2016-11-18 05:04
So the previous version of the Go App worked on an iPhone 5.  What did DJI change that now makes it not working on iPhone 5 or is it just a DJI/Apple way to get people to buy new devices.
2016-11-18 12:50:14
DJI Natalia
Satstream Posted at 2016-11-18 21:04
And what about user Pmarten8? He has an iPhone 5S and it does not work. He posted it under discuss ...
I've reported the case for iPhone 5S, and will get it fixed in the next version.
2016-11-18 20:28:10
george_007
Flight distance : 54000
Sweden
DJI Natalia Posted at 2016-11-19 05:28
Please do the same for IPad 4.
2016-11-19 02:04:13
TV-PressPass
Honestly I can't believe this sort of patching out of compatibility is treated as okay. It's absolutely ridiculous. My Phantom 3 should be grounded right now, as I uninstalled a previous version of the app in late October, only to find it was no longer compatible with my iPhone 5 when I went to reinstall this evening.
By a stroke of luck I still have an older version of the DJI GO app running on an iPad 2 that allows me to update my unit's firmware and access the camera controls. But that device is even older than the iPhone 5 and I have no doubt that I could not install the latest version of the app on it now.
I rely on my drone as part of my small business income, and it abosolutely enrages me that with no change to hardware my software connection could be rendered unusable at the drop of a hat. If I could roll back to earlier versions of the app, I would. As of now I'm going to have to juggle devices using a much larger iPad 2 with the remote control.
Poor show DJI. I want to jump to a Phantom 4 Pro next year, but not if it's going to mean update issues like this.
2016-11-26 19:03:37
DJI-Jamie
Flight distance : 34261
george_007 Posted at 2016-11-19 18:04
The iPad 4 is not a recommended device, we would not be able to guarantee its compatibility.
2016-11-26 23:32:17
DJI-Jamie
TV-PressPass Posted at 2016-11-27 11:03
Honestly I can't believe this sort of patching out of compatibility is treated as okay. It's absolut ...
As the Go app continues to receive updates, it requires more processing power in order to run. Older versions of the Go app may have been more forgiving to older hardware, but in general iOS devices need to have an A7 processor or higher in order to run efficiently.
2016-11-26 23:37:25
fans59d020fe
Flight distance : 124026
iPhone 5c worked prior to the last update. It is completely unacceptable to make a device no longer supported when it worked fine in the previous app version.
DJI Please hire better IOS developers.  I don't see this issue arising on Android devices. Luckily I own both in the future I will likely stop purchasing IOS devices if this is how DJI plans to handle updates.
2016-11-29 07:33:24
Hummingbird.UAV
DJI-Jamie Posted at 2016-11-27 00:37
As the Go app continues to receive updates, it requires more processing power in order to run. Old ...
Maybe DJI should have more than one piloting app in both iOS and Android.  You keep adding more and more hardware to the mix all controlled from the same app which then has to have more code to work with all the hardware, which requires more processing power from the control device.
I expect most recent updates to the Go app are not to fix bugs but to add more hardware support.
2016-11-29 09:34:02
fans3a89f5aa
Flight distance : 1400669
I used my old iPhone 5 for long time with only my Osmo it worked perfect
for the Osmo, now I cant even use it for that :-(
2016-11-29 12:31:08
DJI-Jamie
Hummingbird.UAV Posted at 2016-11-30 01:34
Maybe DJI should have more than one piloting app in both iOS and Android.  You keep adding more an ...
It's been a mixture of both fixing and adding with most of the updates. DJI used to have separate apps per drone series, but customers began provided feedback that there were too many apps to juggle with those with multiple products which resulted in the multi platform Go app. DJI is starting to separate apps again in their own way with the release of teh GO 4.0 app, which only supports the Inspire 2, Mavic and the P4 Pro/+ at this time. This should help with processor taxation in the future.
2016-11-29 13:24:17
george_007
Sweden
Today all of a sudden I could install 3.1.1 on my iPad 4. Has DJI changed their policy?
2016-12-5 23:46:17
Hummingbird.UAV
DJI Go version 3.1.1 has now installed on my iPhone 5. Thanks DJI software team.
2016-12-6 14:50:11
Alanthg
DJI Natalia Posted at 2016-11-18 04:04
I have an iPad 4th gen running 10.2.1 OS I have been running the Phantom 4 on it since new last August  this week i see the update of software to 4.0 which when I try to install say is incompatible with my iPad REALLY how could you do that?  I pads must be the most common viewing device by far  Are you in league with Apple???  why cant I still use the older version  of what 2 weeks ago?
2017-3-29 01:04:53
fans1ce7791b
where can I get the dji go version 3.1.1 for my i phone 5? The app store only has 4.0
2017-4-13 20:03:33
fans1ce7791b
Hummingbird.UAV Posted at 2016-12-6 14:50
How did you get  version 3.1.1
2017-4-13 20:04:06
Hummingbird.UAV
fans1ce7791b Posted at 2017-4-13 20:04
Got is a few months ago, now its up to version 3.1.9.  This version does not work with Mavic or Phantom 4.  Last version to do this was 3.1.5
2017-4-14 12:22:29
hyprfrco
Flight distance : 3093
Chile
DJI Logic:
iPhone 5 is not in the compatible list, hence this device cannot work with DJI GO......
DJI GO cannot be installed in an iPhone 5, hence iPhone 5 is not in the compatible list.......
Nice job DJI
2017-5-16 22:02:34
Aardvark
Flight distance : 86901
One potential solution might be if DJI provided access to all previous versions, but to only offer support. Warranty repair work only for latest release, and where aircraft less than 12 months old ?
Having a limited list is understandable from a business point of view otherwise it would be unlimited, and that's disregarding older devices that may not be fit for purpose now.
2017-5-17 00:04:08
Satstream
I use the iPhone 5 no longer, for my iPad Air 2 for the control of the P4. There is, however, already a version of the Go app which also works on the 5er. (Europe)
2017-5-17 03:37:21
fans47c0bb7e
Brazil
Thank you DJI! Now I have to buy another iPhone! And guess what? I LIVE IN BRAZIL AND AN IPHONE 6 HERE COSTS U$900!!!
2017-6-10 10:23:45
djiuser_dBCMX3K
Got my unit home, all excited for my first flight, and I find that none of my devices are compatible with the app.
I wish the guy at the store who sold it to me had picked that up when I showed him what I planned on using with it.
I see some people on here have been able to download version 3 which I'm trying now.
Are there any warnings or problems with warranty when using this older version?
2017-7-3 01:11:27
exeterdown
v3 doesn't work.
Online Support weren't able to help me download previous versions like the earlier posts I saw.
I'd like to be able to edit or delete my previous post, but can't.
Have to go buy a new phone.
2017-7-3 02:39:21
Mattobie82
So i've just gone from Android to IOS iPhone 5. I'm now unable to fly my drone which I have literally just bought. This is a poor show from DJI! Please tell me the difference between the 5 and the 5c
2017-9-18 02:32:49
Mattobie82
Mattobie82 Posted at 2017-9-18 02:32
Should have said 5s
2017-9-18 02:33:50
kc9eci
I was thinking about ordering a Mavic until I got to checking out the app.  I still use a iphone 5, have no desire to upgrade at this point.  Guess I'll have to spend my money elsewhere if I want to get a new quadcopter.
2017-11-4 11:07:53
bmwminirc10
Flight distance : 28938
kc9eci Posted at 2017-11-4 11:07
Ok so it is clear apple does not want anyone using an iphone 5 which was released in 2012 (the battery debacle). Dji being an apple partner probably also want us iphone 5 people to drop $1000 on a new phone as that's what apple may have told them. So they
So not fair!!!
2 giants manipulating there consumers so not KOOL!!
2018-1-22 10:47:59
Nebicaneser
Flight distance : 196144
2 giants manipulating there consumers so not KOOL!! totally agreed !!!
2018-1-22 10:54:12
