Davejmedia
Flight distance : 329140 ft
I'm having the same problem with footage copied straight from SD card to high end laptops built in SSD drive which reveals artifacts, pixelated, stutters and breaks up randomly during playback on latest 2016 2.7GHZ 15inch MacBook ProT (Touch Bar) with Phantom 4 latest firmware version 1.2.602, stock 16GB Panasonic Micro SD HC I Class 10 [3], 32GB SanDisk Ultra Micro SD HC I Class 10 [UHS 3] and 64GB Lexar 633X Micro SD XC I Class 10 [UHS 3] filming with stock settings such as Video format MOV, NTSC, White Balance Auto, Style None, Color None and several Video Sizes 4K 4096x2160 @ 24fps, 4K 3840x2160 @ 30fps and 2K 2704x2160 @ 30fps. I plan to step back P4 firmware until the problem is no longer present as It was not an issue in v1.1301 or v1.1.410... As I just recently made the jump straight to v 1.2.602..
