Geebax
The Sandisk Extreme Pro can record 95 Megabytes per second, way fast enough to handle 100 Megabit video. I note that the new Inspire 2 requires miniature SSDs in order to handle the new RAW video modes, it can take two of them plugged in near the batteries.
"washed out video, missing frames, missing files, corrupt files, extremely pixilated videos, I have even had all the videos from gopro record with a really blue tinge for no reason at all, then revert to recording fine after formatting SD. "
In the Phantom, the sensor feeds into a video processing chip, and that chip outputs a scaled down 720p stream to feed back to the RC unit, and the same chip has a complete SD card interface built into it. The digital stream that is recorded has been processed in the vision processor and encoded in H.264, and is then recorded on the SD card. Any problems, such as I have underlined above, are quality issues and are not affected by the quality or speed or otherwise of the SD card. The card is presented with a stream of digital information which it either does or does not record.
Missing frames for example, cannot occur in an MPEG stream. If you are seeing missing frames, it is a problem in the system that is decoding, or replaying the MPEG information, not the system recording it.
If anything goes wrong during the recording, the card simply stops recording, and there can be many reasons for that. The most common one is using a card that does not have the speed rating required, or continuing to record on the SD card after many sequences of copying or deleting of files. Most people do not realise that there are hidden folders and files on the card, and even though you delete the video files, the hidden folders are getting larger and larger, eventually impacting on the ability to record properly.
The best practice is to copy your files off the card after a flying session, then immediately format the card in the aircraft. When you format, all the hidden files are erased and the card is in pristine condition to write again.
