Inspire 1 dimensions in travel mode
2602 5 2015-2-8
kw9924.yahoo
Hi guys, could anyone provide the dimensions of the Inspire 1 when it is in travel mode?
2015-2-8
GB44
Flight distance : 343848 ft
510mm wide x 440mm ( This dimension is the area looking down on the aircarft whilst in its case)
190mm ( Depth - approximately)
2015-2-9
kw9924.yahoo
GB44 Posted at 2015-2-9 17:23
19 ...
Thank you GB 44. I am still waiting for mine and now planning to get a Pelican case
2015-2-9
GB44
kw9924.yahoo Posted at 2015-2-9 18:15
Ok I think you will need the Peli im2875.
  There is some photos on the forum of a guy who shows the whole DJI case fitting into the Peli 2875 so it is obviously the right one unless you want it bigger to store more things.
There is also a US firm who sells this peli case with custom foam for the Inspire.
Hope this helps
2015-2-9
kw9924.yahoo
GB44 Posted at 2015-2-9 18:35
  There is some photos on the forum of a guy who shows t ...
Thanks GB44. It does help. I will order the iM2875, which should be the same as the one shown by AerialMediaPros.com
2015-2-9
kw9924.yahoo
2015-2-9
