Dji Go PROBLEM MAP
1132 5 2016-11-20
Melo
Flight distance : 3469603 ft
Brazil
With the last update the aerial map does not follow the drone anymore, a fact that makes it difficult to locate and return the equipment when it is out of sight. Each update is making the equipment worse !!!!!! The equipment is more efficient with Google Maps, Here is very bad. Is the company losing focus?
Thanks
Dimitri de Melo e Silva
BRAZIL
EQUIPAMENT:
PHANTOM 4
2016-11-20
proimages
Flight distance : 1004731 ft
I was having issues getting map up. P3S latest updates..Also seems front light toggle is missing too..there testing staff needs some help or something.
2016-11-20
fansece3c62e
Same prob,
2016-11-24
fansece3c62e
fansece3c62e Posted at 2016-11-24 12:01
Same prob,
Im using a Samsung Galaxy S7.
2016-11-24
DRONE-flies-YOU
Flight distance : 1450594 ft
proimages Posted at 2016-11-20 14:53
I was having issues getting map up. P3S latest updates..Also seems front light toggle is missing too ...
No, they PURPOSELY got rid of the light toggle in the menu.  Lame, right?
They say you 'can' set it to the C1 & C2, as if those aren't already carefully allocated...
2016-11-24
DRONE-flies-YOU
That is because it is the HERE Maps
Yes, Google Maps is the ONLY choice they 'should' use.  Hopefully this change is short-lived.
2016-11-24
