Aardvark
Flight distance : 384432 ft
The use of DJI Go is briefly covered in the manual, but you are right it could be a lot better.
You can 'cache' your maps at home if you know where you will be flying. I often fly without map because usually always have visual contact (and no cellular). Even with a ground reference point it can be difficult to spot sometimes.
The radar is straight forward to use. If you imagine you are standing in centre of radar, it shows the orientation of the aircraft in relation to you. Rotate so that it points towards centre (red arrow), make sure you have enough height, push right stick forward and watch distance reading decrease as it approaches you. If it's windy decrease height if safe to do so through FPV or direct visual contact. |
