Mavic Gimbal Cover
1496 7 2016-11-21
ericmoss
Flight distance : 74337 ft
hi,
is it true that the gimbal protector should not be used in flight due to overheating problems?
regards
2016-11-21
DJI Natalia
Super Moderator
Flight distance : 318 ft
You could check the info in the manual, gimbal cover is used to protect the gimbal, you can remove it when necessary.
2016-11-21
Schwavic
It covers the air intake, so it will make your internal parts a little hotter...  Not extreme, but it will shorten the overall life.
2016-11-21
Mooney
Not convinced 5 degrees at the sink is really diminishing the life of the circuits.
Keep in mind that forward flight will be flowing air over the sink.
2016-11-21
ericmoss
thank you for the comments and film
2016-11-21
sanuk
I think the main reason not to use the gimbal in flight is not over-heating (although that might be a risk), but that the gimbal cover is just a piece of cheap plastic designed to protect the gimbal, not optical quality glass. Hence it will degrade camera image quality if used in flight.
2016-11-21
CADDJockey
Flight distance : 163934 ft
I thought about flying with it on, but after learning about blocking the cooling, I had second thoughts.  IMO, the cover doesn't snap in strong enough to protect the gimbal during a crash.  If you already have experience flying a quad copter with reasonable control - especially a cheap one, then you shouldn't have anything to worry about.  That's my experience so far.
2016-11-21
FlameBoy
Flight distance : 105558 ft
I love kitchen science it's such a joke
5 degrees F difference is nothing. 2 drones should be used as the drone is already warm (leaving it for 60 seconds between tests is a joke). Also the way the drone is designed, it's self cooling using the props to do most of the work.
I will be flying my drone with the cover on to start off with. Why?
The drone is self cooling while in flight.
I'm new to this drone so in case i fly into a tree the cover will protect the gimbal from branches ripping it off.
If i fly straight into something in sports mode the cover will also protect the gimbal (as it's clips in forwards).
Will the cover give me great video? No but do i care when i learning the controls...
2016-11-22
